Coolingmist kit installation ?'s
fwdturbobov1996
1,504
8
Feb 27, 2004
Blue Springs, Missouri
Got the kit today, had to send it back b/c they gave me a basic kit when I ordered the deluxe. Already have a few questions. Its says to wire it to your ignition wire? Im sure I can just splice into my fuel pump wire as well? Since they turn on at the same time. Also where should I tap the uicp? 6 inches away from the tb? Do I just drill a hole and thread the fitting in there?
Yes, you just drill a hole. Don't make it too big or the threads won't work. And make sure it's sealed good so you don't have boost leaks. Put the injector either on the throttle body elbow or somewhere a couple inches towards the BOV on the UICP.
K thats what I was thinking, now im going to go ahead and do it on the fuel pump wire instead of the ignition wire. cuase well its all getting mounted in the back.
  • Wanted 6 bolt NT water pipe
    • chrisman287
