Coolant return issue
Boosted_talon98
170
Apr 11, 2009
Keyser, West Virginia
I don't have enough posts but need help about this coolant return line. I am running symtech race manifold, GT3582r and this turbo sits so low that my water return is under the water pump metal line in front of block... I am running water supply from heater core. Is there any pressure behind the coolant coming out of my turbo?Also , do I have to have it flowing down for gravity purposes. What are my options. TURBO PROS PLEASE HELP..
For gravity purposes? The cooling system is pressurized.
You should either slightly bend the nipple on the lower pipe or cut it off and weld an AN fitting closer to the pipe.
That should be fine. You really only have to worry about having the oil return pointed down or slightly aft. The cooling lines can be oriented in almost any direction. The cooling system is under something like 15psi of pressure.
Ok thanks mayn. I was alittle worried there for a minute
