coolant lines
xhackerekx
302
Jan 1, 2009
UE/Scranton, Pennsylvania
i really need connect coolant lines to TDO5 turbo 16G or 18G ???
any suggestion ??
i already have 18g in my dsm just simple question need connect coolant lines or can drive without connecting ??
are you asking if you need to connect your coolant lines from the thermostat to the turbo lines or if you can just leave them unhooked and drive, if so why wouldn't you hook them up?
Please type in complete sentence, proper spelling, punctuation, etc. We'd really appreciate it.
If the turbo is a wet housing, then YES you need to connect the coolant lines.
yes turbo have wet housing. when i drive without water line what happen on turbo ?? shorter life ???
Generally, yes. The oil that will be flowing to lubricate the turbo won't be able to cool it down and will see excessive heat, causing shorter oil life, oil coking on the turbo parts, and eventually will probably kill the turbo.
Remember to use proper spelling and complete sentences please.
sorry for my English i try my best.
i use full synthetic oil is more resistant for coking. i try disconnected water line because coolant start leaking from back turbo housing and no have time for remove turbo , nothing change only engine cool down faster. EGT same.
where are you leaking at ??? you could just have a lil crush washer leak, from what i understand you are saying your turbo already has your coolant lines hooked up right ??? if so then leave them on LOLjust see whats leaking man , dont go running without them
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
