coolant lines
obx tsi
199
Dec 1, 2005
Manteo, North Carolina
car had some coolant lines blocked off when purchased. need to know the routing of the coolant lines. i believe that i may have a non turbo water pipe also.
The N/T water pipes are generally used for larger-than-stock turbos that are not water cooled. You can tell if a turbo pipe as there is a large "bung" on the bottom of the pipe on the compressor side. If you turbo is water cooled (14B/16G/20G) then you NEED that line connected to your turbo or it will fail in short order. The water outlet from the turbo connects to the thermostat housing.
The coolant passages in question are likely the FAIV (valve that boost idle speed on cold starts) on the throttle body. A line goes from the water pipe to the TB and then out to the Thermostat housing. It doesn't really matter which way the lines go on the TB. If the prior owner blocked off the FAIV, then no reason to hook up the water lines to the TB :dsm:
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
