2G Coolant line help (missing port?) and VSS plug missing
Jonathanf
May 26, 2019
Winnetka, California
Hello all,
Doing some digging and it appears that I am missing a port for the coolant lines. The previous owner put a brass T fitting in so that the lines would hook up, but I think I am missing a port somewhere. I have searched other posts and mine seams different. Also I found the VSS, but cant find the plug for it. Where do I trace the wire for it too?
Blue is to turbo coolant feed.
green is to turbo coolant exit
red goes to the oil housing feed
purple is the exit to oil housing coolant.
At the location on your block where the arrow is pointing, you should have a feed line for your turbo.
See: 2g Block Coolant Line
