coolant line block off
opendown69
35
Jun 17, 2006
magna, Utah
hey guys i just boaught the t3t4 kit for my talon and i need some pictures on where and how to block off the coolant line and also i have another ? what do you guys think on this is it the clutch or slave cylinder if the clutch pedal stays to the floor i need as much help as i can get
Coolant gets blocked off at the water pipe if im not mistaken. Its a bolt that gets put into the bottom where the feed was.
Just wondering though, if you block off the coolant line feed you would have to block off the return line too wouldn't you? So... couldn't you just run a line from the feed to the return?
freebmx444 said:
just get a rubberhose an put one end on the coolent out and the other end on the coolent return!
Thats all I did on my 50 trim. Not the cleanest/best way... but its probably the quickest.
Trying to dig back in my memory on my 50 trim a while ago. I think I used an old oil pan bolt to block off the coolant line on the water pipe. The other one I plugged.
Due to a history of coolant lines breaking between my friends and I, I prefer a blocked off line compared to another hose.
thanks guys but why does my clutch pedal stick to the floor is the clutch gone or is it the slave cylinder
