coolant light???
mitsuclipsegsx
2,561
8
Apr 5, 2004
Dover plains, New York
This is on my 95 talon, i think its the coolant light? Anyone know why it could be on?
I'm not 100% sure.. but on 1g's we have a sensor in the bottom of our overflow tank and that will trigger the light to come on if there isn't any water in the tank. I figure 2g's would be the same. Also.. are there any other lights on?
Yea thats a different light casue I had the sensor unpluged and its turned on above, but thanks anyways.
I thought the coolant light looked like a carasel (sp?), I believe that would be for the washer bottle located in the trunk under the spare.
As stated, on a 2G there is also a indicator in the overflow resevour bottle by the passenger headlight.
Jim
Yeah that does not look like the coolant symbol i have seen posted unless it was different for the earlier 2gs. Im sure the car manual says what it is.
next time, instead of posting, why don't you just go around your car and check all the fluid levels. if they are all good then you have a different problem, otherwise refill fluids and your good to go.
Next time keep your comment to yourself. And you can"t check the level unless you take spare out ect,thats what this site is for buddy.
