connecting evoscan directly to the ecu
mauricioazua
Jul 26, 2009
viña del mar, South America
Hi!!
i have found in my toys XD an openport cable evoscan-subaru-select-monitor-i that i bought for a subaru legacy 92 , now i have a lancer 93 swap 4g63 and i have some question that maybe you can help me
i have a registered version of evoscan , the laptop takes the usb cable and installed it.
1.- when i connect the cable to the laptop it say evoscan-subaru-select-monitor-i, it this just a name ?? would it work on the 4g63 (both are obd1)
2.- how can i connect it direct to the ECU i have 3 wires (data, self diag, check light)
3.- on different ways that i tried does connect , but only while im moving the negative constantly and the readings arent good.
best regards!
even when the usb cable is the same? the only change is the terminal for ssl (subaru select monitor) and obd1
