Confusion with fuel pressure????
LilGdsm
97
Aug 10, 2004
Orono, Maine
yup, I've searched
I'm confused at what I should set my 1g's fuel pressure to. I should set it to stock levels, but what the hell is that. This is what I've found:
Stock level:
27 psi
with the regulator vacuum hose unplugged and capped:
36-38 psi
Am I suppose to unplug the regulator, cap it, and set the pressure to 37-38 psi?
I should have mentioned I have aftermarket injectors 780cc's. From what I can find online, most aftermarket injectors are rated at 43.5 psi and should be run there. Also I'm finding that people are saying you should run your injectors with stock fuel pressure levels.
anyone with experience here?
