condenser fan operation
comsoldier20
99
Oct 14, 2012
Manchester, New Hampshire
So I am just about finished with my clutch replacement. I have deleted all of the A/C in the car (95 GST)
I am wondering If I need to re install my condenser fan? I have heard that the condenser fan only comes on when A/C is turned on.
since I deleted all my A/C lines, condenser, pulleys. The fan wouldn't be needed?
I plan on installing a new radiator and the stock radiator fan that sits on the passenger side.
I plan on leaving out the condenser fan which sits on the right side. is this correct?
Here's a pic of my corroded radiator that I am replacing. the fan on the left is the condenser and the fan on the right is the radiator fan.
Thanks!
I know there a treads here you can look up. Dsmers will say to keep it wire it up to the regular fan. So they both run together to halp keep temps at a good number and help from going to hot especially now spring and summer is on its way.
Thanks for that diagram. I guess I will just leave my condenser fan plugged into its stock connector so that it will come on if my temps exceed 210 F. I guess this would and should only happen if I get stuck in summer traffic.
Unless anyone recommends I wire it into the radiator circuit?
    • Sdcryan1
