420A Compression Test Results
frostphase
Aug 21, 2014
cedartown, Georgia
So I performed a compression test on this 2G 420a
160 - 165 - 160 - 140
Then I performed a wet test on #4 and got 180 on the gauge.
So is this definitely bad rings? I was really hoping it would be something simpler like valve stem seals...
I get some light blueish smoke during idle.. sometimes, not all the time..
What do you guys think?
Impossible to tell without doing a leakdown test. The smoking could be from valve seals, but the low compression is going to be either rings or valves.
Would pouring a capful of oil in the #4 / 140psi cylinder be considered a "leakdown" test? It shot up to 180psi after doing so..
No, that is a wet compression test. A leakdown test involves pressurizing the cylinder and finding out where the air is leaking from.
