Compression Test on JDM engine
ARTSUPRA
110
Feb 13, 2004
Vancouver,
Did a compression test on my NT JDM motor and found this:
#1 160Dry/192Wet
#2-192 Dry
#3-192 Dry
#4-190 Dry
So it seems #1 is little too low, service limit is 145. Since it's a newly purchased motor it's under warranty.
Not sure if 160PSI an acceptable compression or not, can't decide if I should exchange the engine.
Opinions are welcome:)
anything over a 10% difference is a problem.
My opinion is to take it back.
Why start with something that could progress into a serious problem down the road, after the warranty has expired.
you're probably right.
I'll do another test with Throttle @ WOT tomorrow if get same results than the motor is coming out.:mad:
  • Wanted 6 bolt NT water pipe
    • chrisman287
