compression test help
scaryfastdsm
70
Jan 9, 2008
bonney lake, Washington
i have a 91 gsx and im trying to attemp a compression test.....how to you do it and when i tryed last night i have 90psi.....thats way too low.
explain how to compression test please and what my #s should be.....
Wow, I think that's a new record. 3 posts in 10 minutes. And you're the only one posting! :toobad:
This is against forum rules and is called bumping. Please wait next time and I'm positive someone will be able to help you. A lot of the people on here have other stuff to do besides stalk the new threads. There is also the search button up top which should be used before starting any new threads.
Here's a how-to on doing a compression test.
http://www.geocities.com/dsmgrrrl/FAQs/compression.htm
This will answer all of your questions. But, if you have more, just post back.
No problem. Utilize your resources. That magical search button works wonders. It has answered many of my questions. In fact. Most of my questions have already been answered. All I had to do was use the search. :thumb:
Be a little patient.
Get a compression tester. Take out all the plugs. Hook the tester up to one of the cylinder where the plug was. Crank the car for around 15-20 seconds. Make sure you do this with the throttle plate completely open and the engine warm.
You definitely don't need to crank the car that long to get a reading. I will take about 4-6 revolutions which takes between 5-10 seconds.
That is what I normally do them at to make sure I am getting a good reading since it takes the needle a second to move. But what you said is good enough to tell if you have low compression.
ok thanks for the help sorry for being impatint i just needed to know what my compression was...and i did it yesterday on a cold trial and got 130 acrossed the board.
The links already provided, which are found on the VFAQ, which should be your number one place to look for questions like these, can pretty much answer any question you have about compression testing, including how to do it and the proper specs your car should have.
The attitude, flaming, and incessant bumping will not endear you to many people here.
"scaryfastdsm:
#1) No bumping here, EVER.
#2) Don't bite the hand that feeds. These people are here to help you FOR FREE. Calling them "dicks" won't help your cause at all.
#3) Please use proper punctuation and capitalization when posting in the tech forums on this site.
-99gst_racer"
