compression surge
Talonnightracer
Dec 23, 2005
Perrysburg, Ohio
okay i have a 1995 talon with a 50trim turbo with the greddy type s and it seems to be surging wondering if theres anyway to fix it no matter wich way i turn the spring tension it dosent get any better
Are you sure its compressor surge ? Does it sound like a flutter ? Does it happen after boosting hard ?
Well at low boost its normal for it to flutter. Now if it flutters at high boost you probably have the spring too tight,loosen it just a tad bit. How much boost are you running ?
Wow i don't know how it could be surging then.. Last thing i could think of is to check and make sure your bov is connected good, and if it is make sure it is not stuck close.
