compression #s. good or bad?
wishgst
83
Jul 9, 2008
Brunswick, Ohio
ive got a 95 clipse gst and the compression numbers came back as 175 across the board. don't know how to check what the normal numbers should be so i was wonderin if i could get a quick answer from someone. thanks! ROFL
That's good. Specs for 1G is like 178 from the factory and it can be as low as like 130 as long as the cylinder's compression #'s are within like 14 of each other. I don't imagine it being a huge difference for 2g although it will be a little higher probably.
sweet. was there a previous thread that anyone knows of that says like what the specs are for different years? like 2ga is this... and 2gb is that.. ?
sweeeeet. it says 178 is good so looks like im runnin some pretty decent numbers. thanks for the site. i was worried about a bad HG. how would i know from a compression test if i had a bad HG? (sorry newby questions)
Actually, the best way to find out the source of a leak would be a leakdown test. This will require a leakdown tester (I got one from Snap-on for $300!) and an air compressor capable capable of 100PSI of pressure. I won't go into specifics on how to do the test, but with the test you can find out if your HG, valves, rings, or anything else internal is a culprit.
* edit *
Here's a link to further explain a leakdown test...
http://www.geocities.com/dsmgrrrl/FAQs/leakdown.htm
  • Wanted 6 bolt NT water pipe
    • chrisman287
