Compression results after rebuild
matt98eclipse
1,078
Aug 15, 2006
mesa, Arizona
Today I did a compression test today. My results were pretty good I think. The rebuilt has only 127 miles on it. My question is what do u guys think about the numbers and how many more miles should I go before I can do 8 pounds of boost? Right now I have been boosting around 3 pounds.
1,200
2,180
3,180
4,180
Keep in mind all I did was changed rod bearings and put new rings in motor.
Looks pretty good, it's not too out of the ordinary to have one cylinder with slightly higer compression than the others.
Ring seating is a highly debated topic. The first 20-40 miles are critical in the ring seating process. So with 127miles, your rings are as seated as they'll get. However, over time your #1 cylinder might drop to be closer to the rest.
1,200
2,180
3,180
4,180
Let it sit for now. Let it go another 1000 miles before you turn the boost up. Go ahead and change the oil to remove crap from the fresh rebuild and after 500 miles check it out again.
