compression problems
Shnizzle
44
Apr 21, 2013
Las Vegas, Nevada
guys please help i ran a compression test and they are as follows:
120 120 90 150
a friend on another post recommended a leak down test, i dont know what this is what can you guys recommend?
Here's a fairly in-depth article about what a leak down test is and how to perform it. You should be able to rent a leakdown tester at your local Advance / Autozone.
How to do Cylinder Leak Down Testing- Car Craft Magazine
I don't think I need to tell you that you have a fairly serious issue, as I *believe* 120 is the service limit on compression. 20+ points of varience between cylinders is also a bad sign.
Did you take multiple readings on each cylinder?
no i took the readings one at a time
Thanks that's good info
