coming to a stop car dies
ChefTSI
100
May 14, 2004
Troutdale, Oregon
When i come to a stop the car dies, or when i throw the cluth for a gear the rpms drop real fast and it dies, its only doing this about 80% of the time. Also on a hot start the car idles down real fast and dies, but if i rev it up a few times it comes down to a perfect idle. Im pretty sure its still on the stock duel filter at 72k could that maybe be it? the bov is recerted.
Any advice please.
-Chris
Hey, do you know if your venting your BOV to the atmosphere because those are things that occured when i started to vent to the atmosphere.
he said his bov is recirculated....i had a similar problem to this when i first got my car found out i barely had any oil in the car and my spark plugs and wire was bad.
thanks guys i have an hour before i have to drive 45 min to work in thsi car so im going to go fiddle with it, wish me luck.
this may sound too obvious...but did u play with the BISS screw at all? When i adjusted mine to the factory limit 850rpms...everytime the car would stall coming to a stop or changing gears...i raised it too 950 rpms and it runs fine. :thumb:
ya i didint get time to change the fuel filter, but i got new plugs, new oil and played with the biss screw and it seems to be runing ok now....... i will find out on my way to work i guess. i will get the fuel filter here soon, i also cleaned the injectors and a can of octane booster. The funny thing is i think it might be bad gas i put some cheap ass gas staion gas in it yesterday and it started doing this so.
Wish me luck
-Chris
