Coilovers ?
mossy36
36
Dec 7, 2004
annapolis, Maryland
I have coilovers on my car..they came with it..how do i know if they are down all the way ?? thanks
YOU ARE NOT LIMITED BY THE COIL OVER.
The front upper control arm (by the top of the fender inside) is the limiting factor as is the length of your bumpstops and the shock mounting plates...
I'd look at the suggestions for suspension setup. There is alot more to be done than just lowering via coil over collars... ALOT
