Coil Pack Harness is a mess
rlacasse1
2,666
11
Jan 6, 2009
Scott AFB, Illinois
The above graphic is a crappy power point of the current wiring job done on my 95 Eclipse. It has a 420a. I think it has a coil pack from another car on it because of the yellow connectors and the way the wires all change colors. Does anyone know for sure. Or have a wiring diagram of other coil pack that could be put on a 420a so i can try to figure it out.
Ok. When I am cranking the car over the black/red striped wire has continuous power. The other two did nothing. Shouldn't they be pulsing. And what will cause that to happen.
The one is a power , with key on. The other two are signal wires to the transistor.
the fsm says the power should be black w/ white , yellow green, and yellow black for the signal wires.:|
