coil b primary secondary not working
twiggy333
Aug 1, 2009
stockbridge, Georgia
help!! i have a 1996 eclipse rs it was running fine timing is fine the crank position sensor is working fine from what i tested and the camshaft position sensor but car turns on and automaticly cuts off coil b and starts to misfire and cheak engine light comes on i test it and it says coil b primary and secondary i dont know what to do also i have a broken knock sensor dont know if that has anything to do with it.i also have a new coil pack so coil isnt bad
  • Wanted 6 bolt NT water pipe
    • chrisman287
