Clutch Ticking noise? Pedal sticks to the floor.?? Any ideas?
1GDSM2k3
111
Feb 14, 2003
Evey once in a while im getting a weird noise somewhere in the drive train. It almost sounds like really loud lifter tick. I checked the tranny fluid and my t case recall was done 2 months ago. usually happens after i boost. Strange part is.... it goes away when i step on the clutch. I replaced the slave, rebuilt the master, and put on a ss line. My pedal sticks to the floor here and there too. Seems like ive got a good pedal when i first start the car, then it goes to hell the longer i drive . I have to double clutch to get into gear too. Ive bleed the system many times. Does anybody out there know whats going on with it?
It might be your throw out bearing... the pedal goign to the floor has to be a leak or air in the system.
Try bleeding the clutch really good.
I have the same problem exept i dont think my clutch stuck to the floor ever..Right now my tranny is dropped and the car is a mess. Today i got my throwout bearing even though the one thats in it looks fine. Its a mystery to me. One thing to think about, if u get down under the car check all your motor mounts, i dont know why but one of mine was worn to shit and my friend thinks that was my problem all a long. I doubt it but u never know, u might need to bleed your clutch and the mount is bad....This weekend we're gonna button her up, i'll let u know how that goes...later
Open up the bleeder on your slave cylinder, and then keep adding fluid to the resevoir for about 10 minutes, then close the bleeder.
Make sure you dont let the resevoir get empty or air will get in.
Then bleed it and see if this fixes your problem.
P.S. are you ever running out of fluid and need to add?
