clutch problems
hermangoodgame
Jun 16, 2011
Farwell, Michigan
i have installed a stage 2 clutch and lightened flywheel and couldn't get enough throw on the release arm to disengage the clutch so i replaced the Master and slave cylinder still could not get it to work right so i replaced the clutch with a stock one just in case still having the problem if i pry the release:cry arm the clutch disengage is please help:cry::banghead:
i have installed a stage 2 clutch and lightened flywheel and couldn't get the the release/ fork arm to move enough to disengage the clutch so i replaced the Master and slave cylinder still could not get it to work right so i replaced the stage 2 clutch with a stock one just in case and still having the problem. If i pry the release arm with a pry bar the clutch disengage is
By 'not getting enough throw on the release arm', do you mean you've already loosened the nut up behind the clutch pedal and screwed the stud out a bit? When I installed my 2900, my clutch wouldn't disengage either. To replace the clutch, slave, and master cylinders, you would have had to open the hydraulic line up. If any air got in there (which it would have), you will need to bleed the system several times to purge it all out. Air in the system can be compressed, lessening your mechanical advantage when you push the clutch in. Bleed the system first, and then try lengthening the rod behind the clutch pedal if that doesn't work.
Sounds like a worn pivot ball to me. Don't shim it, if you're going to pull the tranny anyways no sense in bandaiding a $9 fix by putting in a new pivot ball.
