Clutch Problem! Need help ASAP
yankees1919
134
May 1, 2004
Montvale, New Jersey
I just bought a 95 talon tsi about 3-4 weeks ago and it has a new ACT2600 clutch...It drove perfectly fine 2 days ago, sat in my driveway yesterday and now today i go to start it and when im ready to go the clutch is extremely soft...The pedal requires almost no pressure to put it down...Im new to DSM but I did check the clutchmaster fluid and all that and that's fine...It's a new clutch and a new engine so I haven't got on it hard at all and there was no burning of the clutch or nething, so I dont think its the clutch...The tranny is also brand new...ANY HELP ASAP would be really appreciated
Dont know if anyones ever had this problem...But it seems that about 5 minutes after that the clutch felt normal again...Anyone ever had this problem before? Only happened once
dan,
obviously air could easily be the problem. Make sure you try and check the lines, and slave cylender. It is under the car two bolts hold it in on the tranny it has a line going to it also.. I would imagine its fine. I just put this in writing so you have a checklist to go off of.
scott
