clutch pedel vibration. help!
deviousgst
931
Mar 24, 2008
bakersfield, California
Okay this just started happening today, only happens when im driving in any gear I rest my foot on my clutch pedel I can feel it vibrate. Its never done that before till today. I've tried backing up the rod n vise versa but still vibrating. I have an act2600 with a street disk. Both have about 3k miles. Also my pedel was never really stiff like other 2600 clutches I've felt.( mines kinda spongy) if that helps any...please help..thanks in advance
You should not be resting your foot on your clutch pedal period. A little vibration is normal.
I don't actully rest my foot there its just when ima down shift or put it in neutral everyone slightly puts there foot on clutch before so. N its a little more vibration than normal
Now it kinda does it in netural too while cruising. Any ideas why this happening? Ill put my foot up behind the clutch pedel and I can feel it vibrate pretty good and I know not normal
sorry for not updating. i forgot all about this thread. but just to let you guys know i solved my problem. i dropped my transmission down and noticed my TOB was broken into 3 pieces.i think i adjusted my clutch pedel rod too much and caused TOB to be pushed up against clutch even though clutch pedel wasnt even being pressed. i dont if that makes any sense. Aanyways, installed new TOB and its all good now..
here are pictures by the way
[/IMG]
