Clutch pedal problems... Crankwalk?
JeanDSM
405
Jun 23, 2004
Yabucoa, Puerto, Puerto Rico
Its been like 4 month since i have this problem. I push the clutch pedal and when I release it, it only does it halfway up then in a matter of 1 to 2 seconds its all the way up. my gst has 139K miles. Does this has to do somehing with crankwalk?
my car did the same thing when I had a bad clutch and a leaky slave cylinder. Definately check your slave and master cylinder to see if they are leaking fluid.
I'm curious as to if you have or will have any problems in the future with your clutch sticking to the floor. That is usually the case when there is air in the lines or the slave cylinder is bad. I'd say , check fluid check slave cylinder for leaks and then proceed to (bleed and replace)
good luck.
had the same sort of problem, had to replace my master and slave and my clutch, ended up being all of those, you might want to go in and get it looked at
