92PandaTalonTSI
- 97
- 1
- Oct 3, 2011
Bethlehem,
Pennsylvania
Ok guys! Just before I order the parts, my clutch slips at higher rpms. It's still the stock clutch so I want to upgrade. I'm going to buy a clutch kit with a lightweight flywheel. Already did my research on my clutch and flywheel package. Only question is should I get a new pivot ball and clutch fork while I'm doing it? There is a kit on extremepsi.com (my favorite vendor) that is a forged clutch fork with a new pivot ball:
EXTREME PSI : Your #1 Source for In Stock Performance Parts
I'm also going to get an OEM throwout bearing for it. It also has a new slave cylinder and the pedal assembly and the master cylinder looks great. I know the new pivot ball will eliminate the need for shimming and the new clutch fork will ensure that the stock one is not warped at all. Is there anything else I should look out for while it's all apart? Should I upgrade to ARP Flywheel Bolts right away? Do I need an extension rod if upgrading all the other parts too? So my shopping list is as follows:
Clutch (pressure plate and disk)
Flywheel
Pivot Ball
Clutch Fork
OEM Throwout Bearing
OEM Clutch Release Clip
Flywheel
Pivot Ball
Clutch Fork
