Clutch or Transmission prob???
97GsXfreak
137
Nov 15, 2004
Berkeley Heights, New Jersey
I was sitting at a light the other night waiting to race a WRX and i had my car sittin in first. Before the light turned green i gave the wrx a little sound of my car by revving a little but ending up going to 6 grand. Around 6,000 rpm's my car moved forward and i thought it was just me but i tried it again and the same thing happened. Any ideas on what my problem is?????
You had the clutch pushed all the way in and it moved? Sounds like you need to adjust the clutch rod on the pedal assembly. Connected to the clutch pedal is a rod with a nut on it, loosen the nut and turn the rod in or out to get the proper adjustment, it may take a few tries to get right, and don't forget to tighten the nut.
