Clutch hard to shift; seems stuck
hun6over
94
Feb 17, 2007
Bayarea, California
OK so i just finished fixing my overheating problem. Yesterday I fixed my suspension and got my car alligned. I dont know if that has anything to do with my clutch problem but id like everyone to know just in case.
Now a new problem arised. Ok, so this morning as i drove my car for the first time of the day, i noticed that it was harder to shift into gear. As the day went on, it got worse and worse (i had to do alot of driving today). If i try to put it into gear normally, it seems as though it is stuck. It is the same feeling as when you try to shift without stepping on the clutch. I noticed that my clutch pedal is depressed down almost all the way. It doesnt return fully to its normal position. It seems to be stuck in the halfway position but i can still step down on it slightly. Stepping on the clutch doesnt seem to help shifting at all though. I can shift gears even without stepping on the clutch. I also recall being able to be at a complete stop while in first gear without holding down the clutch. I am not 100% sure though.
Any help is appreciated. Thanks.:dsm:
