clutch engages differently?
xreaction122
258
Oct 28, 2007
Albany, New York
okay. i have a bit of annoying problem driving my talon.
in the morning when i first start driving, the clutch engages where it should be. towards the bottom(thats where i like it :D) but once you start driving for a while the clutch engagement point gets higher! only thing i can think of is the slave cylinder on its way..but im not leaking any fluid out and i have a new clutch line. what could be my issue? also, i adjusted the clutch when i got my car because the engagement point was too high for me. ever since then, its doing this. any ideas?
oh and the clutch is ACT2600. clutch shouldnt be slipping since my car has almost no modifications done to it.
I had a similar issue when my slave cylinder was going out. I would change that first since its easiest. Otherwise, master cylinder may be the culprit.
    • Sdcryan1
