Clutch Clicks when pushed in
xcelr8n
1,854
5
Jan 31, 2003
toronto,
Hey guys, my clutch "clicks" when i push it in about 50% of the time, the click always occurs near the bottom of the pedal travel, and only happens when Im stopped and I go to press the clutch in to put it into 1st gear.
There hasnt been any work done in that area in a while so nothing leads me to believe its an error I have made, and it is definitely coming from the tranny area underhood, not under the dash.
Any ideas?
Thanks
I had the same problem. It turned out to be the clutch master cylinder needed to be replaced. They replaced it, the click was gone. It might be the clutch assembly itself as well, but the master cylinder is the cheaper fix, at least for 2gs.
-98talonnt
