Cleaning your headlights?
hubz91talontsi
1,120
5
Jul 30, 2007
bentleyville, Pennsylvania
Ok ive seen some stuff at advanced auto.. But what do you guys use to clean those ugly ass headlights of yours with =] Easy way out is just to buy glass im sure.., but will that stuff at advanced auto work.. Thanks
ive done two things 1. wet sanded with 1200 and 2000 and used a buffer with some compound came out like new the other was just buff and compound... i would sand them with 1200 and then 2000 to smooth them out if they are really really bad
There's 429854893 threads on this buutttt I'll help you out.
Toothpaste believe it or not works a little bit. Just rub some in circle motions around the outside of the lens.
Mothers Aluminum Polish works very well, same concept as toothpaste.
The best idea is to take apart the headlights and rub the Mother's on the inside of the lens. Helps a lot.
Good luck.
Good luck.
I concur with Apeximprt2nr, there are a million threads on this subject. Six97gst wrote a nice thread about it. Thought I would shoot you the address
http://www.dsmtuners.com/forums/showthread.php?t=71434
Have fun!
