Cleaning intake manifold
TWOpointFORliter
645
129
Jul 31, 2009
Crown Point, Indiana
I have read through a few threads on this but they all seem to cover cleaning the inside. I am looking to clean the outside. I just got my evo3 intake manifold and it looks every bit of 16 years old. I would like to make it look as close to new as possible. I do not have access to a bead blaster and do not want it polished, so those option are out. Do you guys have any tips/tricks to cleaning it up? Is there some chemical cleaner out there that works well?
Purple Power and a brillo pad. It a very potent cleaner, but works great!
Purple power? Never heard of it. Is it an automotive cleaner? If so can it be found at autozone/advanced/ect.
Alright I'll pick some up on the way home and give it a try. I post up some before and after pics for others to see in the future.
Check your local autozone/advance/etc, sometimes they have it for $5 a gallon.
I use purple power, then bead blast makes it look like new.
And I do a couple a month for powder coating.
Alumi brite it will turn bnib look. You need to put it on with the intake cool and dry. The stuff is pink and it foams up white when sprayed. I just use an old tooth brush to clean it with. Dont leave it on to long it will turn it gray.
Thanks for all the replies. I stopped by a local machine shop on the way home and they told me they can have it looking new inside and out for $30. I think I am going to go that route and save myself some work.
  • Wanted 6 bolt NT water pipe
    • chrisman287
