Cleaned up
stock1g4g63
1,193
Jan 2, 2003
(was TX) Anaheim, CA, California
Finally had a day off, so decided to clean up the engine bay a bit... sorry for the quality, I think there's something wrong with the digicam, everything's been coming out sans focus.
wow that's clean engine bay. May I ask how you clean your engine bay? My car leak oil due to the head gasket blown. So i'm replacing the head gasket and red valve cover. Wat else should i change and how should i clean it? if you dont mind sharing?
Thanks
Foaming engine degreaser, a toothbrush, and a whole lot of time. Took me about 6-7 hours total from start to finish. I took out almost everything including intercooler piping, intake, etc and cleaned it all individually.
looks nice...non related question..how many coats of that vht night shades stuff did you use on your tail light on the car in your sig? and did you use clear coat, they look very good! also, what headers are you running?
Crappy Ebay headers. Also, I used the entire can for both tailights, a bunch of light coats.
I also used quite a bit, almost the whole can for both the taillights. Then I put about 3 coats of clear on them, sanding them with very fine grit between each coat.
Looking good. Clean engine bay!
Do you guys spray Nightshades on the inside of the tail or right on the outside?
