clanking noise
lupe
Mar 4, 2006
denver, Colorado
Hello all,
Sorry if i'm asking a repetitive question but i cant seem to find an answer I'm new here and new to dsm's I tried a search and found nothing so here it goes, I just bought a 95' eclipse rs with a 420a it has 150k miles everything looks good except I'm getting a clanking noise from the engine when it starts and gets louder as the rev's climb. I also noticed that white smoke comes out of the exaust so i know I'm getting coolant into the combustion chamber the power is low when i drive, I checked for cankwalk according to what I've read but it doesnt seem like its that. I also noticed alot of oil when I pulled the spark plug except for plug # 2 was dry I took the valve cover off everything seems ok, so my question is what do you guys think it is or what direction should i go, what could it be? All I want to do is build this car to run high 12's with the 420a in Denver's high altittude I know I have to build the motor but I'm not worried about the money I'm just doing it for fun. For now I just want to get the clanking noise solved and park my BMW for a little while. Thanks I appreciate any info!!!
lupe said:
Hello all,
sounds like lifter tick, try checking the spacing with a feeler gauge. do a compression check it sounds like you might have a broken head gasket.
DSM.org has a good "How To" article for it.
  • Wanted 6 bolt NT water pipe
    • chrisman287
