Circle Track Laser
1990 Plymouth Laser circle track car with 1993 DOHC 4G63 and manual trans.
Laser Trackers are instruments that accurately measure large objects by determining the positions of optical targets held against those objects. The accuracy of laser trackers is of the order of 0.025 mm over a distance of several metres. Some examples of laser tracker applications are to align airsraft wings during assembly and to align large machine tools To take measurements the technitian first sets up a laser tracker on a tripod with an unobstructed view of the object to be measured. The technician removes a target from the base of the laser tracker and carries it to the object to be measured, moving smoothly to allow the laser tracker to follow the movement of the target. The technician places the target against the object and triggers measurements to be taken at selected points, sometimes by a remote control device. Measurements can be imported into different types of software to plot the points or to calculate deviation from the correct position.
Essay writing service reviews
  • Wanted 6 bolt NT water pipe
    • chrisman287
