Ciggarette Lighter Gauge Placement
97 GSX 97
730
Oct 2, 2007
Perkasie, Pennsylvania
Alright I know I've seen some people dremel out the ciggarette lighter area in a 2G and stick a gauge there. Does anyone have any tips or pictures? I want to stick my AEM Wideband O2 there.
I did this last week, and I can tell you to CONSTANTLY recheck the hole sizing. All I did was remove the console, take out the lighter and start hacking away. I didn't mark off the limits of my planned enlargement, but it's a good idea. I just got out the old gerber and went to work checking to see if the gauge would fit every so often. Also remember to carve carefully, the material is old and it tends to crack with tons of pressure on it. There are to "layers" to the console, the top is a lot softer and easily cracked (ask me how I know LOL) so I suggest angling the knife (or whatever you're using) to take of more on the bottom side than the top, then match the size of the top hole to your needs.:thumb:
Eric
I did this about a week ago. I simple measured the diameter of the gauge. Then made a circle just a bit smaller with a sharpie. It wasn't a perfect circle.
Then I took out an old soldering iron and started melting through the plastic like butter. After I got my hole approximately the size I wanted I started trying to shove the gauge through it.
I would use a file and rasp (round file) to smooth out the hole and slowly enlarge it until the gauge fit with out to much force. Then I took a large o-clamp and put it on the back side of the gauge and tightened it down so that the gauge would not be able to be easily removed.
I have some pics of it after I was done. I didn't really take any while I was doing it. I will look and see if I uploaded them on car domain or somewhere yet.
Pretty bad pics taken with camera phone.
http://www.cardomain.com/ride/3838829/4
I will try and upload some more pictures later tonight when the bandwidth on my satellite connection is restored. I ran over the bandwidth yesterday and it takes 24hrs to restore.
Wow you are smart. I would've never thought of using a soldering iron. I'm assuming that the gauge you used was a 52mm gauge? I'm just making sure 100% that I want to do this before I destroy/cut my mint center console.
Uhm yeah It was what ever the standard size is. Not the Smallest and and not the EFFINF huge one. Just the standard aproxx 2inches gauge you can get at O'Reillys.
Edit:
I did it this way so I can tell what my accurate boost level is and because I don't want my car to look street racer ish.
I can't tell you how many times I have gotten pulled over and the Cop looked at my triple gauge a pillar suspiciously. I am really thinking of make a 3 gauge holder out of plexiglass to mount on top of my single din radio and install it without a dash kit. I want to keep all my gauges in the Center console so they don't attract as much attention.
I went at it with a solder gun today and it looks decent. I'll get pics up later.
Good stuff bro, and man, I wish I would've thought of the soldering iron too LOL. I also put my TT in the coin holder/ thing-a-ma-jig with a lid. I finally reached the same conclusion about using heat, but all I had was my Bic lighter and waaayy too much time on my hands LOL.
I'll get pics up later today in my gallery, especially since I haven't updated the interior in almost 2 years :thumb:
Eric
Here is how I did mine..Just remember to cut it out from the back of the console so its cleaner..Gauge in the pic is a bit hurt so don't mind that..But you get the idea
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
