Check out this knock for me
TSITurbo95
18
Oct 26, 2009
Ohio, Ohio
Ok, attached are 4 logs, from cruising to wot pulls, and I am getting knock. First is really frustrating and confusing me, while cruising, only at a certain rpm and speed, ill get knock, I am not in boost, low throttle, yet it shows 2.5ish degree's of knock, perhaps phantom knock? The other two, are a 3rd gear wot pull and 5th gear wot pull, and get knock on both. Any suggestions would be appreciated. Thanks.
Huh? There was never "goo" in the sensor. And I had already cleaned the maf, and system. This has been a recurring issue for awhile, but am just not getting to it. It happened when the car was basically stock. Phantom knock?
Ah gotcha. I tried looking for it, but can't see around the intake mani. Is there an easier way to get to it without removing a lot of shiot?
Well anyway your really confused because its counts of knock not degrees. Degrees is timing. The knock sensor is under intake.
The mas shouldn't have anything to do with it.
Sent from my Eris using Tapatalk
Wires and plugs were changed about 1,000 miles ago, alternator is good, not sure on coil pack, how do I test that? Also, I installed many grounds on the car with my home made grounding kit. Also car runs really good, just the random knock LOL. How is my afr and timing looking for the wot pulls?
