check engine,went to autozone help!!
mitsuclipsegsx
2,561
8
Apr 5, 2004
Dover plains, New York
3 codes,
fuel trim malf(p0170)
tps (p0120)
cyl 3 missfire(p0303
My plugs are new, wires i dont know, he said maybe the tps caused all of it :rolleyes:
which one is the tps, saying your looking at the engine, the one closest to you? anything i can spray on it,or do i just have to buy another tb
You really need to work on your grammar and spelling. People tend to ream people when they don't take the time to use punctuation, and spell correctly. If you want us to take our time to help you, you need to take the time to write out your thoughts. No aol speak, ellipses all the time, and so on.
Onto your problem.
If you don't have a Haynes/Chilton's manual, invest in one. Also get the dsm shop manuals on cd. They help tons. Learn to use the search function, you'd be surprised at what you find. ;)
p0170 (sounds like 02 sensor. Read Up.)
http://www.dsmtuners.com/forums/showthread.php?t=116422&highlight=p0170
http://www.dsmtuners.com/forums/showthread.php?t=159134&highlight=p0170
http://www.dsmtuners.com/forums/showthread.php?t=164454&highlight=p0170
p0120
http://www.dsmtuners.com/forums/showthread.php?t=67896&highlight=p0120
http://www.dsmtuners.com/forums/showthread.php?t=3231&highlight=p0120
p0303
http://www.dsmtuners.com/forums/showthread.php?t=111861&highlight=p0303
RamenPride said:
umm.... no. it's a sensor as indicated by the name. it may just be out of adjustment. if it's bad, you have to replace it.
what do u mean by out of adjustment?
Throttle Position Sensor... I believe there is an adjuster cable right in front of the throttle body. Check on the 2G engine diagram where it shows everything in the tech articles. I'm not too sure where it is.
