Check engine, No Kar
TSiWarrior
300
10
Feb 17, 2005
Detroit, Michigan
I was ajusting the belt for the altenator, when I noticed my check engine light was on. Upon looking at my SAFC I noticed that there was 0 kar (airflow?). The car is running like hell, studdering...almost like it's misfireing. I pulled off the positive wire from the battery, car still ran. Wiseman please help fast!
check your Mas connectors? if a Zero Karmen reading, id say its in the sensor.
try a know good sensor from a friend.
without a signal the ecu will run in closed loop.
Which isn't good with the mods done to your car. There is no longer any type of compensation for your injectors. All the ECU has to go on is RPM, and it thinks you still have 450cc injectors.
That's an easy fix. This time, run the harness through a wire conduit around the firewall. ;)
