check engine lights on 2g with 6 bolt
sillyme
151
Aug 3, 2005
seattle, Washington
will the dsm link help me get rid of the check engine lights i have? i bypass the egr and ISC with block off plates. gm maf with maft and a boost solenoid code. i'm running pig rich when i hit boost. i'm guessing it's the ecu making it run extra rich due to the trouble codes.
you can connect a few of the sensors and leave then not hooked up. But the MDP needs a pressure source also, that should slove almost all your CEL. And the coolant temp is cause you need the right 2g sensor installed.
The only CEL you should get is EGR malfuction or misfire, the others can all be fixed. The EGR one is a now and then for me with my 6blot swap.
