check engine light
JimmyJ
70
Feb 19, 2003
how do you get rid of the check engine light?i got it after i changed my injectors and my pump. I have 550 injectors and a walbro 255lph.
mine came on after i changed my exauast system and added an intake..it seams when ever i start changing something it will do that... wither a sensor is bad and needs to be replaced or maybe you can do what i did and unplug your computer and let it sit for like an hour... it reset mine and it hasnt come back on since.... i might be wrong so dont quote me..... this is just the actions i took... might not be right...
yeah try resetting your ecu....it should only take a minute or two..unplug your negative battery cable and let it sit, then put it back on
A few weeks ago, I got a check engine light from washing my car. Turned out that washing my car causes O2 sensor heater circuit malfunction.
1fast97gsx said:
were you cleaning it under the hood? That's crazy :laugh:
Nothing under the hood. Damn, I edited my msg after you posted. Maybe you can shed some light on my mystery.
