cheap datalogger
bluetlr2001
510
6
Mar 6, 2006
Louisville, Tennessee
Im looking into getting a data logger but not sure what all i need. And were to get the software. Also im looking for the cheap way out;) . And it doesnt have 2 be for a palm, I have a laptop already but I do want somthing that logs knock. I think it may be doing a little knocking somtimes.:(.
BISHILVR said:
$125 from pocketlogger.com brand new.
I'm also into the market for getting a logger (I have a laptop already also). I've been looking at pocketlogger.com and the obdII cable + software package states halfway down the page that a pda is needed. So add the cost of a pda onto the $125 for the cable + software package.
Someone please correct me if you can just buy this cable+software package and use it with a laptop, cause if so, I'd grab one up in a heartbeat :rocks:
Read this,
If you have an OBD-II vehicle (2g DSM) you may acquire an OBD-II logger cable from Multiplex Engineering. It will be around $85. You want the T16-003 Connector with destination address 0x25 (or just tell them your using Hal Landry software). If you wish to use this adapter for a Laptop, all you need is a null modem cable. There is NO DIY cable for a 2G that will work. I would suggest running the software with a Palm because the Laptop logger program is not well suited.
you need to get the OBD-2 converter ($85) but here it tell you were.
Also there is the program as well wich you can run in the laptop.
Either way if the MMCD will work you still need to get the OBD-2 converter. so either way you are going to have to expend the money. if you cant afford it. sell the car and get 1G so you can DIY.....
PGTred95 said:
MMCD doesn't have an application for 2gs. That's only for 1gs.
MMCD is great software though :thumb:
Here read this....
pocketlogger
Another thread
Does the palm n stien software log knock signal. Bc that is something that i deffinetly want to make sure of.:confused: and also if i get a palm, hotsync cable and the obd2to serial cable with the palm n stien software will that not work or do i still need the adapter.
spyderturbo007 said:
The only thing that will log knock on a 2g is DSMLink. So you are pretty much out of luck with anything else. But there are other ways to tell if you are knocking, but we can get into that after you get your logger and we can look at the logs. :sneaky:
True, you can tell by timing, the O2/WDB reading.. etc...
bluetlr2001 said:
Oh well guess ill do with out that part.:( . But back to my other question IF i buy the obd2 to serial cable and put with the hotsync cable and palm do i still need the adapter mentioned from above
nope.
and i suggest you do it that way too.
just buy a $15 palm off ebay and get the $125 cable/sopftware from pocketlogger.com
