Changing manifolds cracked 1g to evo 9
frankenstein406
347
Dec 18, 2008
hell, Wisconsin
My buddys selling me his evo9 pump and mani for $70, but I'm worried about breaking a stud so is it ok to cut the nuts in half and buy new ones? Then run a thread fixer over them? Also will I need a new exhaust gasket for it? Trying to do all the maintence I can find before spring. Thanks everyone! :D
I hope he's charging you $70 for the pump and throwing in the manifold for free, because that manifold will never work on your car. It'll bolt to the head, but nothing else.
Shit so I need the 8? :(
Try lower....like 3.
Nope, you need an evo3 manifold if you want an evo manifold. Also I would just ignore your studs unless they break.
The evo9 pump is a good choice but it isn't entirely safe without an AFPR. Mine overruns my stock regulator. Avoid evo8 fuel pumps because they have a pressure relief valve that makes them minimally useful if you run your turbo over about 20psi.
