rocker_topper
- 126
- 0
- Jan 11, 2012
marianna,
Florida
Anyone know if this is possible? If so how? Changing cams and don't wanna have to retime if I don't have to.
I would take the extra 20 or 30 minutes and just retime the engine. In this situation you definitely wanna be safe rather than sorry. When was the last time the belt and hg were changed? If they weren't done recently, now would be a good time to do so.
A head gasket isn't really a maintenance item. It really isn't a good idea to just replace it for no reason. The water pump, tensioner pulleys and tensioner on the other hand are maintenance items and should be replaced in certain intervals.
Well I see where you coming from with that but if that head has been on that car for the life of that car, lets say the op has 120,000 miles on that head, I would definitely wanna go ahead and replace it while I have all those components apart along with the water pump and tensioners as well. If it isnt bad right now you dont have to change it but why not, its not hard to do.
Is this a real question.... If your doing performance upgrades, and asking a question like this, then you should retrun the parts you purchased.
If your going cams, you HAVE to re-time, to do it correctly. Might as well do the Water pump, Replace the tensioner with a mechanical one (thank me later when it takes you 2 mins to time), Head hasket and get your head checked out. yes it costs $$, but its worth it to do it right, or blow your engine, either way.
It is like ten times more work to go ahead and change the head gasket. I assume that changing a head gasket it over this guys head any way because he is not even wanting to re time the engine.
Miguel: I cant belive if the head were off that you wouldnt have it checked. 50$, if that is cheap insurance to make sure when whoever puts it back together its done right.. .. Not checking only means your a true DSM half asser. thats a fact. .. and actually, yes.. i have everything checked.. i just dont put evo gears in b.c this is a NT forum.. not your 4G6X stuff, which you should go back to..Just because you half ass a car doesnt mean others should. The money you spend up front to to take all the unkonw variables out of a long equation is worth it. Any real performace shop would suggest the same. Granted hes not a shop, we didnt tell him to rip the engine out.. He was simply doing a proceedure that was allready 3/4 of the way into another proceedure (head gasket) that would give him more life (headgasket change etc). since he just recently did those (we/I was not aware) then no, he doesnt need to to do them again..no one cares about your pic.. thats not even the engine hes working on..
Sorry Paul, its hard to stay civil when dam near every NT post has some gst/X guy chiming in , with no clue.. they feel so "entitled" b.c they are already turbo , so they must know. *Note: not every gst/x guy is unknolegeable about our platform, just most of them* -end rant-
"Engine was just rebuilt. mechanical tensioner installed along with new water pump and timing belt. bought a new head and now I have a set of cams from and I can retime this thing np was just wandering if it was possible." Good, Youve done some home work, thats good! Then you ###### dont need to do any of the 'basic maint" stuff as youve already done it. Knowing that id say slap them in and Re-time. with the mechanical tensioner, youve saved yourself headache : )
Dont forget to replace cam seals : ) GL on it. it sound slike you (OP) know what ## doing for the most part . cheers.
I can't believe you guys are telling him to change head gasket........Come on guys, the OP needs an advice of cam removing and not taking his car apart to do such thing (Head Gasket, Head Checked).
To the OP, It is possible but not recommended, .............The main point is to keep the belt tight, so it doesn't jump the crank.
Agreed. We are actually talking about cam caps and cam gear bolts. Nowhere near pull the head.
This^
I did do cams one time using a variation of Miguel's method. I did it because I basically wanted to see how hard it would be. I didn't like it and it was not fun. I will not do that again.
But I absolutely understand the drive/thought process behind doing it. I change a lot of stuff up top often (from racing and testing). I actually do have a tool in mind that I could make that would make it much easier. But until I do, I'll not go that route again.
Imo, if you want to try it, go ahead. Just be aware of the worst case scenario of screwing up the timing enough so that you hit valves.
MB
which is why I am going to re-time this thing. hardest part of re timing is pulling the crank pulley off. That's why I didn't want to do it if there was a way. Anyone know of a way to time without removing the crank pulley? That will decrease working time by about 20 minutes or more there cause I won't have to fool with the alternator or its belt.
It's really easy to swap cams if you make/buy the tensioner tool (just a long bot). You can swap cams without pulling the timing belt / timing cover off. You just need to make sure and use some bungie cords to hold tension on the timing belt so it doesn't jump a tooth at the crank. Make sure timing marks are lined up before you pull it apart so it's easy to verify it's correct when you put it back together. Put marks on the timing belt as well so you KNOW where it goes on the cam gears. It's probably best to zip tie the belt to the cam gears, but still mark the belt too just in case they jump at any point during the process. I've done this a few times, and it's SO much easier than pulling the belt all the way off the engine. ONLY do this if you have a fairly fresh timing belt, if you have a decent amount of miles on the belt or if the teeth are cracked, get a new one along with the bearings and water pump.
The lifters might extend when you pull the cams out, so make sure and let it sit for a while before you crank it over once it's back together (or just pull the lifters and bleed them).
Why not just zip tie the cam sprockets to the belt, release the tensioner pressure with a long bolt, and change one cam at a time while holding upward pressure on the cam sprocket the entire time the cam is removed.
There are several ways to make sure the crank stays at TDC, and it's easy enough to check without removing the lower timing cover. The worst case senario is that the rear balance shaft could come out of sync if you get sloppy.
EDIT: ^^^ Beat me to it! ^^^ That's to be expected when I walk away from my computer mid-post
Bullet come on.. If he is redoing timing like he should ( agreed not impossible, but why not redo it) hes pretty close to removing the head. only what an exhaust manifold and some Head bolts stand in his way? Im alittle surprised that a person with ## level of DSM know how isnt agreeing. Granted he already changed that stuff, and i also agree, no need to go back over it. But if he had not, which we were orginally assuming, then im a little surprised the "while your in there" wouldnt have a pplied. Oh well, GL OP, i think youve got it.
Not everyone goes by this theory. It isn't half-assing anything to not replace a head gasket while you have the valve cover and timing belt off. There is no need to go replacing things that aren't broken. When you have been working on cars for a long time you realize that there is no point.
Why not just zip tie the cam sprockets to the belt, release the tensioner pressure with a long bolt, EDIT: ^^^ Beat me to it! ^^^ That's to be expected when I walk away from my computer mid-post
. Since chrylser and mitsu are one and tge same, I would say I am a master of your 420a. Hell, since I popped the hood on a Mercedes once and seen daimlier chrysler on the hood. Im pretty much an expert at mercs too.
. Its kinda like a crossfire, just fancy and whatnot.
