changed water pump / how to set my timing
turbomoe
86
Oct 2, 2007
LINCOLN PARK, Michigan
okay my water pump went out.. that was no biggie but now i need to set my timing belt... i cant seem to get it right .. can some one please help with a diagram or somthing
Yes definitely get the tensioner tool and compress the tensioner. Set the timing marks accordingly. On the ecentric pulley you will see two holes in them, set them so that its points to 11 and 1 o'clock. this should be it, turn the crank a couple time to insure the timing marks line up again at tdc.
are they the same for a 6 bolt and a 7 bolt? cause in that diagram i think its a 6 bolt cause my tenn. dont not look like that.. mine has a bolt on each side
