cas harness location
damianb401
32
Sep 13, 2008
woonsocket, Rhode Island
ok so I realized that my cas has no harness attached to it but the car runs fine. can anyone tell me where the harness is located on a 2g?
What do you mean it has no harness attatched to it? Both three pin plugs should end up on the cam gear side of the motor from behind the fuel rail.....You're 96 cam sensor is coming from behind the cam gear, the crank sensor plug is bolted with 2 10mm bolt to the plate behind the intake cam gear.
I still want to know what you mean by no harness attatched to it?
