cas compatability
I know 90s are stand alone as far as ecu,tps,iac, and the cas cause I've owned 7 of them .When I put my 93 together I used all the 93 components ,so I'm kinda curious with my collection of 90 parts what's swapable .....can I swap the complete throttle body and cas if I just wire them in to the same plug/pig tail that it goes to. Parameters will be the same I'm guessing ? Tps range ,iac movement and cas rotation are gonna be read by the 91 and up computers properly?
You can if you want to, but i don't understand why you would want to put all the 90 parts on there when the 91+ are more available and don't require and wiring. You can easily sell those 90 parts and buy the 91+ parts.
