carrier bearing question
chris7156
31
Apr 28, 2009
Heath, Ohio
I would just like to know if it is possible to put the carrier bearing on backwards. I was replacing them both and wasnt thinking much about it, but when i got my driveshaft bolted up, the rear end and the rear carrier bearing bolted up nicely but the front one doesnt even come close to being level on the studs under the car. When you put in the bushings there is no way it even comes close to being able to bolt up. If it is backwards is there any good way to taking the bearing off without ripping the rubber. I would hate to destroy an 80 dollar bearing and never get to use it. Thanks
