car wont turn over..HELP..
boostd-spyder96
44
Sep 20, 2008
jackson, Tennessee
ok i've been having problem with my 97 spyder(4g63t swap) it started off with a wire shorting out which ran back to the MFI relay so i replaced that and now the car doesn't even turn over NOTHING..when i turn the ignition to the on the check engine light comes on for about 5 sec then goes away so im pretty sure my ecu is good.also when i turn the key i dont hear the fuel pump kick on for some reason..if my cam or crank angle sensor was bad it would still atleast turn over right???what would cause the car from starting at all???:confused: any help would be GREAT im getting sick of working on it.
you can check it with a multimeter. +/- and have some one try to turn it over. if you get 12.5 its working if not than that could b your problem.
check starter.. good way to see if its the starter is take a long extention or pipe and reach down between the battery and intake and hit the starter while someone cranks it.. sometime the selonoid gets stuck and you have to "hit" it to free it up..
